dragging icons to working area, the icons are not showing.
try reloading icons and updating axure - no result
Icons not showing
Hi MaartenJongmans,
If youâre still running into this issue after jamesorior suggestion, would you happen to have any âSketch Effectsâ enabled in your projectâs default page style? You can check this by going to âProject > Page Style Editorâ in RPâs menu and selecting the âDefaultâ page style:
If the âFontâ option here is set to anything other than âApplied Fontâ, this could be interfering with your Font Awesome icons (as it would override the âFont Awesomeâ font on them). Changing this option back to âApplied Fontâ should allow your widgets to retain their original fonts.
I hope this is helpful!
Tx for your reply.
I checked the setting and it is as your suggestions.
Also form elements dont show
see screenshot
Uninstalled / installed latest Axure - no result
Hope to hear from you soon.
rgds
Maarten
Maybe the icons are not acutally graphics but an icon font.
If you havenât installed and activated that font, this could explain why the icons donât show up.
Thank you @Zuvala for your Reply.
It actually is the default Form elements so I have âapplied fontâ selected
Hi Maarten,
If youâre also seeing this issue with the default widget libraries in RP, can you try reloading all of the affected libraries? You can do that by clicking the hamburger icon next to the âLibrariesâ pane and then selecting the âLoad Libraryâ option. For Windows, you can find Axure RPâs default libraries at the following path:
C:\Program Files (x86)\Axure\Axure RP 8\DefaultSettings\Libraries
If that didnât help, could you tell us what build of RP youâre currently using, as well as your computerâs operating system version? Any additional information you can provide may help as well. Iâll be standing by!
Hi fuying,
Do you still need help? If so, could you describe in a little more detail about the issue you are running into? A screenshot or video would be helpful as well. Thanks!
This library thing is a reccurent problem. If you load back the libraries from the link given above, it only solves the problem temporarily.
I did it and again, the library (for the moment, only Flow) does not display the icons (and items are not working at all in fact).
Starting to really annoy me.
(am working on Axure Pro 8.1.0.3379)
Very much the same here.
You can reload the library and shows icons, flowchart, default etc.
But after few days the issue comes back again.
Hi @xfranck and @MaartenJongmans,
We just pushed out a new release candidate build (3380) that should include a fix for the issue where the icons go missing from the default libraries. Could you guys give that a try at www.axure.com/rc, and let us know whether the issue persists or otherwise?
Hi ,
none of the above mentioned measures worked for me, only default widgets are displayed correctly when dragged onto the page/canvas. The downloaded and custom ones loaded and displayed in Library view but not rendered on the canvas.
Could you please help?
