In RP11 (version 11.0.0.4122), the keyboard shortcut for “Publish to Axure Cloud” is CMD + Backwards slash: ⌘\
Note, in prior RP versions, this shortcut was performed by pressing CMD + Forward slash: ⌘/
The 1Password app also has a ⌘\ shortcut (for searching your password vault) which when enabled (it’s enabled by default) takes precedence as a keyboard shortcut over other installed apps.
This means that if you press ⌘\ while in Axure RP11, you’ll get a 1Password search prompt instead of the Axure dialog to publish to Axure Cloud.
This is easy to remedy.
- Open 1Password on your Mac.
- Navigate via the menu bar: 1Password > Settings > General
- Scroll down to the “Keyboard Shortcuts” section, and remove (or change) the shortcut value for “Autofill”
CMD + Backwards slash ⌘: “Publish to Axure Cloud” will now work in Axure RP11.
