Invisible SVG icons in Editor
Many SVG icons that we use, when added to an Axure project, are invisible in the editor, but visible when running the mock.
Example SVG:
<svg width="16" height="16" viewBox="0 0 16 16" fill="none" xmlns="http://www.w3.org/2000/svg">
<path fill-rule="evenodd" clip-rule="evenodd" d="M0 3C0 1.89543 0.895431 1 2 1H14C15.1046 1 16 1.89543 16 3V13C16 14.1046 15.1046 15 14 15H1.5C0.671573 15 0 14.3284 0 13.5V3ZM2 2C1.44772 2 1 2.44772 1 3V13.5C1 13.7761 1.22386 14 1.5 14H14C14.5523 14 15 13.5523 15 13V3C15 2.44772 14.5523 2 14 2H2Z" fill="#313233" style="fill:#313233;fill:color(display-p3 0.1922 0.1961 0.2000);fill-opacity:1;"/>
</svg>
It looks like RP doesn’t like this style property. If you remove it, it seems to render. We’ll look into it.
Can you tell me where the SVG is from?
Thank you. It was exported from Figma like all of our icons.
Looks like this is how they got exported from Figma:
Note the color profile setting, which was set to ‘P3’.
I can confirm that when switching the Color profile to sRGB, then this issue does no longer occur. Thank you very much for the quick help. A fix for this issue would be great nevertheless.
Thanks for figuring out where it was coming from. We will look for a fix.
