Right now, I am exploring the InVision – like responsive design option for Axure demos: The idea is to have the UI content presented as a dynamic panel with a background image. This way, this UI could be made fully fluid, depending on the user’s window size/ratio.
The difficult part comes with the highlights (flashing dots) that indicate specific UI areas and trigger descriptive pop-ups. These highlights ‘seat’ on the layer on top of the dynamic panel with the background image. Ideally, they should change their x/y location (in the context of this solution, it would be more like the x position would be, for example, 5/12th of the total width and the y position would be, for example, 7/12th of the total height), depending on the user’s widow size/ratio dynamically. I am struggling with finding a universal formula that can dynamically place the highlights over the pre-determined UI areas no matter what size/ratio the window is.
InVision-like fluid Axure demo.rp (356.3 KB)
If you have such a formula, it would be a tremendous help in creating a really interesting responsive Axure demo solution.
Thank you in advance,
Natalie
