I am wondering if it is possible to create gradients in Axure 8? For example, if I have an input field that has an inner gradient applied from white to gray and a border on the outside, is it possible to create that in Axure, or would I still need to import an image and use it as a background for the input field?
The short answer is yes, but not in a text field. You can create them on boxes, so your best bet, if you really need a gradient in a text field, is to set the text field to have no fill and place a box with a gradient behind it.
Thank you! I was able to add gradients to boxes, but I figured I would have to use backgrounds for the input fields.
As niki_h said this basically make use of a box with gradient,
no border,
with corner radius
and the textbox is set to transparent
