I have duplicated a project. But the plugins are missing. Is there a way to import the plugins?
Is there a way to import plugins from one project to another
MichaelSaba
#2
If you want to import track content the audio and MIDI regions) and channel strip settings from another project , you use another project import option. Choose File→ Import →Logic Projects. In the dialog that appears, select the project from which you want to import and then click Import. Here is an example:
