Hello,
I have encountered an issue in Axure where lines drawn at a vertical 90° angle shift position when their size is adjusted between even pixel values (e.g., 16 pixels to 14 pixels). However, this issue does not occur with odd pixel values (e.g., 13, 15, 17, 19 pixels).
Could you please check and fix this issue?
Thank you!
This is a known issue that we’ve filed on our end. It occurs when a widget is rotated 90 or 270 degrees and when the widget width is odd and height is even (or vice versa).
By default when you make a line using the L single key shortcut or tool bar function, it will create “horizontal lines”. To use vertical lines, you can search “Vertical Line” in the widget library and this way, they won’t be rotated.
