Moses
1
I want to create a text field with e-mail input and the input must be in English instead of other languages.
it there a way of doing it ?
Basically this is what I want:
OnKeyUp
if text on This equals value (not english)
Set text on This equal to “”
Thanks,
nkrisc
2
That’s not really possible. How would you know if it’s English or not?
The word “Die” is both English and German, for example. You’d have to somehow integrate a language detection service.
mbc66
3
Google has an API for this with their Translate tool: https://cloud.google.com/translate/docs/ including detecting languages.
Hmmm, sounds like a job for Gregor …or nkrisc ![:wink: :wink:](https://forum.axure.com/images/emoji/twitter/wink.png?v=6)
Moses
4
Maybe I should have pointed out that the language that I don’t want to be in the e-mail text field is Hebrew, which is nothing like English or German ![:slight_smile: :slight_smile:](https://forum.axure.com/images/emoji/twitter/slight_smile.png?v=6)
nkrisc
5
Then you might be able to use cases like so:
IF Text on widget WidgetName IS alphanumeric
Do your thing
ELSE IF true
What happens when the first case is false
That might not consider non-Latin characters, such as Hebrew, as not “alpha” which might work for what you need then. Give that a shot.
If you do this Axure. What happens in production. Better to simulate it.
Moses
7
Almost working, but
“.” (dot) and “@” sign are not alphanumeric
