Mac m2 macOS Sequoia 版本15.0.1,卡顿严重,无法使用。
运行环境是:mac m2 系统macOS Sequoia 版本15.0.1,系统CPU总负载20%;
axure11版本为:11.0.0.4118。程序运行后卡顿严重,系统监测到axure11应用运行时仅占用了系统2%的CPU,但是依旧卡顿严重,已经到无法继续操作的地步。
在卡顿时继续操作,会报错:系统无响应;最终一段时间后程序卡死。 重制axure11也无法解决该问题;
这问题很严重,请帮忙排查,如果无法解决我只能尝试退回mac的系统版本。
Hi @ziyer,
I’ve had to translate your message, so I apologize in advance for any miscommunication.
Mac m2 macOS Sequoia version 15.0.1, serious lag, unusable
The operating environment is: mac m2 system macOS Sequoia version 15.0.1, the total system CPU load is 20%;
The axure11 version is: 11.0.0.4118. After the program was run, the lag was severe. The system detected that the axure11 application only occupied 2% of the system’s CPU when it was running. However, the lag was still severe and the operation was no longer possible.
If you continue to operate when it is stuck, an error will be reported: The system is not responding; eventually the program will freeze after a period of time. Remaking axure11 cannot solve this problem;
This problem is very serious. Please help to troubleshoot. If it cannot be solved, I can only try to return to the mac system version.
To troubleshoot this issue, could you send the .rp file you were working with to support@axure.com, along with the error logs? The error logs can be found by going to “Help > Show Troubleshooting Logs” from the main menu of RP. Please also let us know if this issue is specific to RP 11, or if you experienced this issue with previous RP versions, e.g. RP 10, as well.
一般是因为使用了云端组件库,而云服务器在国外,导致的加载过慢带来的卡顿,把云端组件库删除掉,不要在Axure内使用云端的组件库应该就可以了。
终于解决了困扰好久的问题,感谢大佬。。。。。。。。。
我在国内搭了一个AxureCloud云平台,访问速度快,有需要的话可以了解一下。http://cloud.hiaxure.com
