Hi All,
Here is a quick experiment on resizing widgets based on amount of drag. Hint drag the third row.
I wanted to add rotation for the icon (rotate in), but if you have Set Size with anchor point != top left, animations get triggered sequentially rather than in parallel. This is a bug I had pointed out previously and hope it will be resolved soon.
This “modulation” can be used for rotating items as well (think Swipe to Rotate as in Tinder). Similarly this can be used to fade gradually a widget. However, Axure 8 does not support gradual fade, but with this method you can pull it off: Set Opacity of a Widget via Drag
light_forger
light_forger - 8.0 beta Drag To Resize CTA.rp (361 KB)
