I regularly work with keyboard inputs for my prototypes. I’m having an issue where i want to be able to hold one key, hold down another key, then release them both and have both of their key up events play out.
What happens is only the key up event of the second key plays out. You can see an example in the attached file. Try holding A, then B, then let go of both.
I could manually have the A Key Up event play when letting go of B, but I’d like to find a cleaner way to handle this. Any suggestions?
Thank you!
key_up_down.rp (44.3 KB)
