Navigation bar links
I have a component nav bar with a drop down menu, containing four links.
I want to select a link in the nav bar, to a page that has four tabs. Depending on the link I select, I want that tab selected in the destination page.
Is this something that can be done in Axure?
Yes, you can do that in Axure! When you click a link in the dropdown menu, you can send a value to the new page, like using a global variable or adding something to the page URL. Then on the new page, you can set it up so when the page loads, it checks that value and shows the matching tab as selected. This helps the page know which tab to open based on the link you clicked. It’s a simple setup and works well for this kind of navigation. If you want, I can explain step by step how to do it!
That seems like a big ask, but I would love that! Thank you!
