Hi Hai–It sounds like the keyboard on your OS isn’t hiding after you have completed typing in your text fields. The device keyboard should hide itself automatically after the text field loses focus, such as when you tap outside of the text field or on another widget. On Android, using the device’s back button should also close the keyboard.
If the above methods of defocusing the text field don’t work in your prototype, then we have a few questions:
- What version and build of Axure RP are you using? Is it the latest build of version 8 (build 3338)?
- What OS is your mobile device running?
- Is the issue happening in your mobile browser, in the Axure Share app, or both?
- If possible, please send a copy of the file or a sample file that demonstrates the issue so that we can take a look. If you’d rather not post the file here, you can send it over to support@axure.com so that we can assist via email.
