improvements you’ve done on numberfield in the editor are cool (increment/decrement by one with arrow can be a time saver for some properties).
IMAO you should have a consistent scrolling behavior between numeric dropdown (ie. Font size) and numeric fields (ie. padding).
More than just a little time saver, this way end users will have a more flexible control over the property (adding/removing ten in a second, …).
Another addition to this would be to allow modifiers for propertie changing (ie. shift + mouse wheel to ad/remove ten by ten as shift + keyarrow do for the widget position)
Regards.
