Scroll to widget not working in Axure 9 during onload of a dynamic panel. Do we have any other alternativeonLoad ScrolltoWidget.rp (58.5 KB)
There is an issue with scrolling to widget OnLoad in Axure 9. Try placing a Wait 0 ms command just before the Scroll to widget command, which was the solution recommended by the Axure staff.
Hi all!
That’s correct, there is a known issue that we are currently investigating where scrolling to a widget OnLoad is not functioning as expected. I’ll be adding a note to our filed report regarding your experience with this behavior. The workaround josephxbrick mentioned, where a Wait action is added before the Scroll to action fires, should do the trick in the meantime!
Thank you!
