Hi there - I’ve got a strange issue with a specific interaction on an Axure Share project.
Basically, I have a repeater that is simulating a search result listing. When the search result page is loaded, OnPageLoad checks:
- Whether the search term (a global variable) should be applied to the whole table
- If it shouldn’t, it checks for individual filters against each of the table columns (I handle these with a search bar master that loads search facets from more global variables)
- The page then applies the appropriate filters
- If the result of the applied filters is zero, the page then hides the search table header, pagination and shows a ‘No Results’ message
- The page then moves a group of Next/End controls for pagination to wherever the pagination repeater is (as it can vary in length)
Now the weird part - the bolded step above works completely fine in browser preview and if I generate the project files. It doesn’t work at all in Axure Share. It’s not that it doesn’t fire - it’s not present in the console trace.
Here’s a picture of the logic, in case that helps. Note that the pagination movement works fine regardless.
Things I’ve tried with no effect:
- Changing the order of the pagination and no results actions
- Attaching the NoResults action to the repeater itself (didn’t work at all, either on preview or in AxShare)
- Adding a longer delay to the no results action (I’ve previously seen AxShare trip over too many actions too close together) - up to 2000ms with no change
