Hi…been trying to use the sample UI pattern predictive search module, and I’ve not seen this question posed, so I’ll ask it…how would I call a dynamic panel if a selection in the “dropdown” was made. I’ve tried to trigger from “Items Loaded” section, not having any luck. I’m missing where the logic should be triggered…any help would be great. thx!
Ah…i think i found the answer…did a bit more digging, if I select the Search Result input…found the click or tap interaction…i can put it there and it works. Hope this helps others. Thx.
