I have a question for the professionals.
I have a prototype where the user can vertically sort three panels on a homepage using a dialog. The dialog has three widgets that drag vertically to sort. Also, a checkbox that hides the panel on the homepage. Sort works fine, but when I hide any panel using the checkbox, the panel doesn’t pull up to fill the gap. I did set the hide to include Push Pull widgets. I have included a example file. example.rp (119.2 KB)
The issue has to do with the order in which all the different interactions are firing. A better method would be to move all the panels first, so they are in the right order, then set the visibility. This way the push/pull doesn’t conflict with the positioning set by the move. Also, since the move specifically places the panels’ positions, you don’t need to “push” when the panel is shown.
Hi Huban,
IT WORKS GREAT!!
I see… all I had to do was move the shows to the bottom so they are last. That way the push doesn’t brake. I was focused too much on the checkbox state. Thank you so much for your help. Is there a tip jar on this forum?
