I have a dynamic panel that is set to “fit to content” and uses the push/pull widgets when changing the panel state to push/pull the content below down as the dynamic panel changes sizes between states.
With the adaptive views, the dynamic panel is able to keep it’s state across views, however the push/pull of the widgets does not happen across views.
Is this a bug / limitation? Does anyone have a workaround for this situation?
