Repeater, chart, JavaScript
I am a UX professional. Currently, I am capable of using JS code to call ECharts within Axure to display charts. However, I am now facing an issue.
Previously, I hard - coded the data in the JS code, but now I want to retrieve data from a repeater. After consulting AI and conducting multiple ,troubleshooting sessions, I have finally pinpointed the problem to the following code:
var repeater = $axure.repeater.getRepeaterByName(‘Label2’);
var dataRows = repeater.getDataItems();
var titleText = dataRows[0].value;
When I use F12 to debug the web page, it indicates that the ‘getRepeaterByName’ function cannot be found. I have difficulty understanding the official API documentation, and the official support has informed me that custom JS is not supported. I’m currently stuck at this point. Could any experienced tech experts in the community help me take a look?
The following is the complete JS code:
javascript:
$axure.utils.loadJS(‘https://registry.npmmirror.com/echarts/5.5.1/files/dist/echarts.min.js’);
setTimeout(function(){
var dom = $(‘[data-label=Demo]’).get(0);
var Chart = echarts.init(dom);
var option = {
title: {
text: titleText,
subtext: ‘Fake Data’,
left: ‘center’
tooltip: {
trigger: ‘item’
legend: {
orient: ‘vertical’,
left: ‘left’
series: [
type: ‘pie’,
radius: ‘50%’,
data: [
{ value: 1048, name: ‘Search Engine’ },
{ value: 735, name: ‘Direct’ },
{ value: 580, name: ‘Email’ },
{ value: 484, name: ‘Union Ads’ },
{ value: 300, name: ‘Video Ads’ }
emphasis: {
itemStyle: {
shadowBlur: 10,
shadowOffsetX: 0,
shadowColor: ‘rgba(0, 0, 0, 0.5)’
if (option && typeof option === “object”){
Chart.setOption(option, true);
}}, 2000);
repeater.rp (46.5 KB)
Thank you for being here.
reperater data.rp (52.5 KB)
I noticed there is a “data” below. I want to use a for loop to obtain the data from the repeater. The naming is fine, but the data from the repeater was not obtained. I really want to know where the problem lies.
If you have time, please take a look : ) :slightly_smiling_face:
加QQ群 :558143802
中继器里拿到data,需要先转成echarts的格式再用
repeater.rp (45.9 KB)
