I want to pick an instance of the “item” repeater (like “triangle”) and review in the “mapping” repeater in which colors the item exists. Then I want to retrieve the color labels from the “color” repeater which indeed exist (“green” and “blue”).
B/c there for sure is much more data in the “color” repeater and much more crossings, I want to keep the mapping idea (instead of removing the “mapping” repeater, and in the “color” repeater showing nearly-identical rows several times, like “green triangle” and “blue triangle”).
The longer answer depends on a lot of factors, but the biggest one is understanding how repeaters actually work. Repeaters are awesome but they aren’t as intuitive as they appear.
Repeaters simulate database-like functionality but they don’t work like one. There’s nothing like a “back-end call” in Axure. Repeaters render one row at a time, independently from one another.
As far as Axure is concerned, any data not rendered in the HTML doesn’t exist. This means timing is everything: have all the repeaters you want to use completely loaded before the logic to filter the “real” list is activated?
It’s also tricky using an event “inside” a repeater to trigger and event “outside” the repeater. If you look around the forums, you’ll see examples of how people use “invisible” events on widgets (OnRotate or OnMove are some of the most common ones), to trigger logic on another widget. It’s a bit like calling a function in traditional coding.
Honestly, it’s been a long time since I’ve needed to do anything that complicated with Axure. It’d probably take me a few days of playing around to remember how to make it all work. This might help at least start your search: Repeater delay - each row - no local variable, no wait-fx
