Repeater Table - Add Row and update the row value above
#1
Hello, I am kind of new to Axure and working on my first project.
I have created a repeater table with 5 columns
Column 1: Number (starting with 1)
Column 2: Date start
Column 3: Date end
Column 4: click to delete row
Column 5: click to add row below
If I simulate the page it shows one row with a time range, for example:
1 | 01.09.2023 | 30.09.2023 | click to delete | click to add row below
after clicking the column 5 in a specificrow I would like to add a row below that selected row:
With following Interaction:
Click or tap
Add Rows
tblOverview add 1 row
now the “Date end” field of the row above should get empty and the value should be put into the field “Date end” of the new row “Date end”
e.g.:
1 | 01.09.2023 | | click to delete | click to add row below
2 | | 30.09.2023 | click to delete | click to add row below
This works already (when clicking add row, I save the value of this.DateEnd into a global variable, delete the value out of this.DateEnd and write the value of the global variable into the new row while creating it.
Next step:
If I adjust the table manually for example new end date for Row1 “15.09.2023”
The startDate of Row2 shall be set 1 day later to “16.09.2023”. And vice versa, if I set the start date manually, the end date of the row should be adjusted on day before the start date.
Is it possible to simulate this in Axure?
Further If I add a new row it is always added at the end of the repeater.
Is it possible to add the row after the the selected row?
Many thanks.
And kind regards,
Alex
