Possibly a dumb question - but haven’t bothered to figure it out despite having done a lot of really complex prototypes:
Why does the MouseOver state of a object not get reset to default when the object is hidden?
i.e. I have a close button on a dynamic panel and hover over it and it changes to its mouseover state. The onClick of the button hides the panel. Then another function on the screen causes the panel to reappear, but now the close button is stuck into MouseOver from having had hovered over it to click it when it closed the panel. This mouseover state stays on until you hover on and off the button again.
Is there a way to programmatically(eventwise) fire off something to tell the object to be in its default state, so that I can reset the hoverstate in the onclick as the panel closes? I know you can do that with selected, but how with MouseOver? Otherwise it stays stuck on when the object is redisplayed.
Hopefully my query is clear without me having to do a demo .rp file.
there’s probably a simple work around but it escapes me at present…
thanks
