Is there a way we can resize the size of a box according to the drag value? It did not work properly. It worked only when I explicitly defined the value for width and height. Any workaround for this would be appreciated.
These recent threads might help you. If not, could you be more specific about what you are trying to achieve and how your table column and/or box widget should behave? What specifically does not work properly? Could you attach your .rp file? …etc.
