Resize snap is not working as expected
Hello, using the beta, resizing 2 boxes the snap to line is off by a few pixels making it impossible to resize two objects to the same size.
Thanks for working on the Beta, it’s looking promising.
Yes, I found the same issue.
It seems to be only on the vertical axis.
The error also occurs in the horizontal axis and only 1 Pixel
This is a HUGE BUG. I rely heavily on the resize snapping in my workflow. And after testing it myself, nothing lines up perfectly like it used to :sweat: Both vertical and horizontal resizing seems to be off by a pixel or two. Please fix asap. Thank you.
Edit: You are right after bigger magnification I can clearly see they are 1px off
Strange on my beta it is looking perfectly aligned…dunno whats happening. Do you use Mac or win ?
Karel
Hi guys,
It does look like the resize snap is off by 1-2 pixels, and I’ve filed a bug report with our QA team about this, so that we can get this fixed up as soon as possible.
Thanks for catching this!
This new Axure is quite a mess.
when I zoom in, my widgets are visually misaligned but according to the x and they are correct. This is just terrible to work with. Accurate scaling isn’t an option for a program like this, it’s a must.
