We´re working with an Axure file, that has hundreds of pages. Unfortunately in RP 9 the window to select pages for generating the spec has shrinked to a little square - so it´s very inconvenient to get the pages you want and you can´t resize the frame. Could you make the window tall again? Thanks!
(Would also be great to have a search function to easily find the pages to select
In a larger house it would be great if the documentation generation system was smarter. We work with 1 huge master spec, but update that entire document infrequently. What we do all the time however is update sections (separated by header) of an Axure file that we need to review separately. In other words we just want to generate a document based on what sections have changed in the RP file. Instead of having to select just the pages we worked on, it would be nice of Axure had a mode where only the pages we worked on during a session are selected in the tree of the document generation window. In most cases we could just open the dialog and execute the generate command and have what we wanted.
Thanks,
Ben
