Hello everyone,
I’ve been looking for a solution to this problem for a long time and I thought maybe you’ve had it too:
I would like to have 2 buttons which, when pressed, show a hidden message containing a counter. If you press one button, the counter counts up, if you press the other, it counts down. The message should be shown for 3 seconds and then hide.
→ However, it should NOT hide if a button is pressed again during the show. The 3-second counter should then be reset and the message should only hide after the time has elapsed
.I use the “Wait” command, which causes the message to fade in and out chaotically… ![]()
I have attached a sketch to explain this better.
Have you already had this problem and can you help me? ![]()
