At particular width/height proportions, at least one of the shapes gets “tails”. Moving it around leaves artifacts that go away when you scroll it out of view, but the “tails” do not go away.
See examples here
See examples here
Hi! Are you seeing this specifically for custom drawn widgets (or widgets with edited points), and does this has to be viewed at a certain zoom level to trigger? I wasn’t able to reproduce the issue in a quick test, but if you can note the steps you take to trigger this on a widget from scratch then we can make sure this is filed. Thank you!
It happens with any zoom level. It’s specifically from the shape highlighted here (or the one next to it) https://i.imgur.com/rAa6MYs.png
Aha, I was able to reproduce it! I’ll go ahead and file this on our end. Thanks for the report!
