The Sketch Plug-In doesn’t seem to be working, I updated to 0.9.3. When I copy either selections or Art Boards using the plug-in nothing pastes over to Ax9. I can Copy SVG from Sketch, paste and Convert to SVG fine. So I’m pretty sure its not copy/paste issue.
Hi KavaKiwi,
I’m sorry to hear that! Could you send the .sketch file over to support@axure.com so that I could take a closer look? In the meantime, please make sure you’re running the latest version of Sketch (51.3).
Hi Jane,
Unfortunately, I can’t send over my .sketch file. However, I did create a new .sketch file and copied over some of the UI elements from the original .sketch file onto this new one. I then tested it again and it works. So I’m going to assume that it’s a corrupted .sketch file and not Axure.
