SVG I made in Illustrator not scaling properly in Axure
UPDATE
So One thing that’s worked is Ive selected all my objects in illustrator and then I clicked make Compound path. From there I clicked on the compound path layer nad on the actual compound path layer inside it and then saved as svg. I’m not sure if this is the correct way as it is a bit convoluted but in case anyone has a similar problem to me this is how I got around it. It now imports as SVG but the scaling doesn’t break now and it’s all one object.
Hi, I’ve made an Icon in illustrator consisting of 2 shapes, here(png just to show you);
Truck_01
Now I save this as a SVG and when I open it in Axure the scaling doesnt stay the same, when I enlarge or shrink it. examples, you can see the discrepencies and distance values are wrong from the original above it distorts the Icon I’m making.
Is there something I’m doing wrong? I click on Convert to SVG and still when I scale up or down it creates these problems.
Things I’ve tried:
Converting to SVG in Axure (I do this all the time though)
Grouping the 2 objects in Illustrator and saving as selection as SVG
Here is the Truck SVG in axure;
I’m wondering why as an SVG you can see all the objects it should be treated as one no? Could this be the problem?
Still having this issue in axure 10
Right click on the SVG in Axure, then select Transform > Convert SVG to Shapes.
If there are still two separate shapes, select both and right click Transform > Combine to make them into a single shape.
