Hi all,
I want to swipe two things (dots and rectangle) at the same time (see link below), however they are swiping seperate but not at the same time/simultaneously. What do I have to change???
Thanks for your help.
Hi all,
Without seeing your .rp file, we’ll have to guess at how you set this up. I can make a guess at your prototype structure, but would be much better if you could post your source .rp file here.
It looks like you have a dynamic panel (dp) for the color squares and are using Swipe Left and **Swipe Right" to change panel states. I cannot tell how the carousel dots (ellipses) are structured, so here are methods that should work for several common ways this might be set up…
Set Panel State MyDots to next
Panel State Changed
Case 1
If state of This equals State1
Set Panel State
MyDots to State1
Case 2
Else if state of This equals State2
Set Panel State
MyDots to State2
Case 3
Else if state of This equals State3
Set Panel State
MyDots to State3
Panel State Changed
Case 1
Set Selected/Checked
MyDot1 to “true”
Case 2
MyDot2 to “true”
Case 3
MyDot3 to “true”
Panel State Changed
Case 1
Move
MyBlueDot to ( , [[LVAR1.left]] )
Case 2
Move
Case 3
Move
Move MyDot to ( , [[LVAR1.left]]) ease out cubic 500 ms
Thanks a lot for your help! I figured it out now
