I’ve been encountering an issue when entering text in Axure 9 whereby the editable area switches from inserting characters to overwriting them. I have to select the “Insert” key on my keyboard to reverse the switch. This is happening only in Axure.
I have:
enabled and disabled the Single Key Shortcuts preference setting
checked the Windows keyboard settings
reinstalled Axure
While not a major issue, it’s pretty frustrating to have to toggle the input mode every time I enter text. Any insight that addresses the issue would, consequently, be gratefully received.
Specs
Axure Team 9.0.0.3727
Windows: 10 Enterprise, 10.0.19043 Build 19043
Machine: Lenovo MT 20QQ BU Think FM ThinkPad P53
Input: Perixx Periboard-612 wireless (2.4Gh) dual mode
I’ve never seen this in many years of using Axure (Axure 9.0.0.3727 and Win 10 currently.)
I recommend you send an email to support@axure.com with this info and attach a sample .rp file. They don’t monitor this forum for support (although support agents do sometimes post here.) I’ve found they respond pretty quickly to emails (which you can send from Axure via Help > Contact Support…
I think I’ve already found the cause of the problem. When entering the editing state, I’m used to quickly clicking the left mouse button three times in a row. However, this operation can lead to different outcomes: when the time interval between the last two clicks is extremely short, the system will enter the replacement editing mode; but if the time interval between the last two clicks is relatively long, the system will enter the insertion editing mode. In order to avoid this situation, the solution I’ve found is as follows: double-click the left mouse button first to enter the editing state, and then click once. Remember not to click the left mouse button three times in a row.
