toLocaleString() produces different results with addition (+) vs subtraction (-) operators
Environment
  • Axure RP 11
  • Variables: LVAR1 = “5,000”, LVAR2 = 1
Issue Description
I’m experiencing unexpected behavior with toLocaleString() when used with different arithmetic operators in expressions.
Test Case 1: Subtraction works correctly
[[ (LVAR1.replace(',','') - (LVAR2*5000)).toLocaleString() ]]
Expected result: 5,000
Actual result: 5,000
Test Case 2: Addition produces date format
[[ (LVAR1.replace(',','') + (LVAR2*5000)).toLocaleString() ]]
Expected result: 10,000
Actual result: 1970. 1. 1. 오전 9:00:10 (Date format)
Test Case 3: Without toLocaleString()
[[ (LVAR1.replace(',','') + (LVAR2*5000)) ]]
Result: 10000 (Calculation works correctly)
Test Case 4: Pure number addition still fails
[[ (5000 + (LVAR2*5000)).toLocaleString() ]]
Test Case 5: Literal number works
[[ 10000.toLocaleString() ]]
Result: 10,000
Workaround Found
Using double negation with subtraction operator works:
[[ (LVAR1.replace(',','') - (-(LVAR2*5000))).toLocaleString() ]]
Result: 10,000
Question
Why does toLocaleString() treat the result of addition (+) as a Date object but treats the result of subtraction (-) as a Number? Is this intended behavior or a bug?
The calculation itself works correctly (returns 10000), but applying .toLocaleString() to an addition result converts it to a date format, while subtraction results format correctly as numbers.
[[Math
.floor ((LVAR1.replace(‘,’,‘’) + (LVAR2*5000)).toLocaleString() ]]
