我自己账户建的团队项目,修改完无法签入
我自己账户建的团队项目,修改完无法签入,提示如下:
您的帐户无权访问KLUT3A的项目。如果您被邀请到工作区,请登录到Axure Share接受邀请。
Team project built by my own account, unable to check in after modification
The team project built by my own account cannot be checked in after the modification. The prompts are as follows:
Your account does not have access to KLUT3A’s projects. If you are invited to the workspace, please log in to Axure Share to accept the invitation.
Hi! Hmm, to confirm are you using the public Axure Cloud at <app.axure.cloud> to host your project? If you created the team project on the cloud, the as long as you’re still logged in to the same account that created it then you shouldn’t run into issues. If you switched accounts, then as long as your account has been invited (and accepted the invitation for) the shared workspace that contains the team project then likewise you should be able to check in changes. If you’re still running into trouble though then please send the following information over to support@axure.com so that we can take a look and assist:
  1. The email address of the account that you created the project on, and that you’re currently logged into when checking in changes
  2. A video of how the issue is triggered
This will help to advise and make sure that nothing buggy is going on. Thank you!
