设置元件显示时向下推动下部 的原件,不能把编组后的元件组一起向下推
设置元件显示时向下推动下部 的原件,不能把编组后的原件组一起向下推。希望如果我对下部的元件编组后,再设置显示时向下或向其它方向推动元件能够把整组的推动,面不是只推动正下方的那一个元件。
Hi @carejoe,
When configuring an element to push items below it downward upon becoming visible, the system currently fails to shift the entire group if the lower elements are grouped together; instead, it only moves the specific element directly beneath it. I would like the system to shift the entire group—rather than just the single element directly underneath—when the visibility setting triggers a downward (or directional) shift.
What you described should work as expected, i.e., push all widgets below the hidden widget on show. I’ve attached an example file to demonstrate this.
If you were trying to show a widget that is nested inside another dynamic panel, then this will require some extra interactions to push the widgets outside of the panel to account for the hidden widget in the nested panel. I’ve also added this as an example to the attached file.
If you’re seeing different behavior, would you be able to post your .rp file so I can take a closer look? If you’d rather keep the file private, please email the file to support@axure.com and we can further troubleshoot through there. Thanks!
PushEX.rp (56.1 KB)
