We’ve got 2 repeaters, each with the same 2 columns:
- Name
- URL
Both repeaters have the same interaction onClick:
Open [[Item.URL]] in popup window
This works fine in the first repeater (the one where all the data is loaded when the page loads). You click on an item and a popup window loads containing the correct URL.
However, when you move an item to the 2nd repeater, the popup window does not appear. On hover, the cursor turns into a pointer, indicating that there is some sort of OnClick interaction. However, when you click, nothing happens.
You can see this in action here:
https://lp3ohx.axshare.com/#g=1&p=board_trial_v2
Try dragging from Applied to Shortlist and then opening the popup.
