I would like to report you a bug:
when using the on click> show> traeat as lightbox, and setting a background color, it works fine, but when you want to edit this color, and see the result on Preview, you won’t see the result, no matter if you will close and reopen the program, the preview will remember the previous setting, I had to clear the whole on click command and re write it in order to just set the lightbox background color
FYI
Hi Eran_Bar_Sinai!
I just tested this out on my end, and was able to reproduce this behavior when editing the background color for treat as lightbox styling as well! This behavior looks to be unexpected, so I’ll be filing a bug report regarding this issue with our respective teams on your behalf. Thank you!
