Hi! I took a look at your file and came up with some modifications that get your file most of the way there.
To get a parent node to select all children, you can leverage the values stored in [[Item.Path]] (which is what tells the prototype what is a parent and what is a child) and use Update Rows to update the Checkbox column to “Checked” for all rows that contain the same value as what [[Item.Path]] has for the current row. E.g. if you click on the checkbox for the row that has the path value “01.01.01”, it will update the Checkbox column for the rows with path values “01.01.01.01” and “01.01.01.02”. Here’s the rule for that interaction:
[[TargetItem.Path.indexOf(Item.Path) >= 0]]
To get a selected child node checkbox to put the parent nodes above it into a “mixed” state, you can update the Checkbox column to “Mixed” for any rows where [[Item.index]] is less than that of the current row (e.g. the rows above the current row) and where the length of the Path value for those rows is less than the length of the Path value for the current row (so that the child nodes above the selected node don’t get selected).
This should get you part of the way there. I’ve attached an edited version of your file with the changes above. The checkboxes seem to work as expected when interacting with the top branch, though the “HMI” and “IP Address” boxes can be a little wonky. Hopefully that helps to give you ideas!
