Hi all,
I just wanted to chime in with an update on this. Currently, you can implement Typekit fonts into your project with the use of AxShare plugins.
However, in order to use Typekit fonts locally in Axure RP, you will need to have access to a Mac. Unfortunately, in our testing we’ve found that fonts handled by Adobe Creative Cloud work in the Mac version of Axure RP, but not the PC version.
For PCs, the underlying problem is a lack of support on the part of Typekit for .NET applications using WPF (Windows Presentation Foundation)–of which Axure RP is one. We have this issue filed with our development team, but ultimately, this may not be technically possible for us to address from our side. It may be up to Typekit to implement support for WPF before you’ll be able to enjoy an integration on the PC side.
If you are using a Mac and would like to use a Typekit font in your project, here are some general instructions for how to do that:
- Go to Typekit, locate the fonts you want to use, and sync them to your desktop using the Creative Cloud application so they can be used in Axure RP. Here is an article from Typekit’s website that explains how to do this.
You may need to restart Axure RP in order to see your fonts listed.
Once you’ve used the fonts in your project, go ahead and publish it to AxShare.
Create and publish a “kit” with your font and associate it with the domain for your AxShare project (this will use your project’s 6-character AxShare ID–i.e. YOURID.axshare.com). Here’s more information on how to create and publish a kit.
The instructions will also include a section about the embed code–you’ll use this in step 7. For now you just need to create and publish the kit.
- In Axure RP, you’ll want to map your font to its proper font-family using the “Font Mapping” tab of the Generate HTML dialog. You can find the font-family listed in the Adobe Typekit Editor with a “.tk-” at the beginning of it. For example, I used Sanvito Pro, which has a font-family of “sanvito-pro” as seen in the screenshot below.
Re-publish your project to AxShare so the font mapping is included
Log into AxShare, choose your project name from the list, and add a plugin
Name your plugin, leave the location as “End of the head”, and in the content box, paste the embed code given to you in the kit editor
Add the plugin to any pages featuring the Typekit font and save the plugin
Now you can test out your AxShare project on a computer without the font installed to make sure it works!
