I had created an upload file, later clicking over the that image is not previewing after I select from the local folder. how can you help me out here in this.
Hi venkataramana,
It sounds like you’re running into some unexpected behavior around uploading images via the image widget in Axure RP. Could you describe this issue in a little more detail and if possible, send over a screenshot of what you’re seeing on your end? Also, what operating system version is your computer running, and which build of Axure RP are you currently using? You can check RP’s build number by going to “Help > About Axure RP” in the menu.
This information will help give us a good platform for troubleshooting. I’ll be standing by in the meantime!
