when will it be available the api to use with rp8 projects.
can i use the current api to do a xml extract on rp8 project?
Using API on rp8 projects
cablewalker
#1
Simon_Axure
#2
Hi cablewalker,
While there isn’t a built-in feature that can export RP projects as XML files, you can try doing this by using the Axure RP API and a bit of coding. You can download the API from our website here:
The download link there includes a sample XML Generation Project written in C#. Please note that it is generally recommended that you have some experience working with C# or writing code before getting into the API. If you have access to a dev team, they may be able to help you here as well.
cablewalker
#3
thnks i do have experience working with c#, i was just wondering if there was any elements on RP8 files that the API would not reckongnize when parsing files done on RP8
