I posted a few weeks back asking for best Team Cloud practices. With zero responses, I scoured the forum and web and (finally) found info on how to get access to a Team Library.
What I cannot find for the life of me is how to create a team Components file that everyone can access without having to import.
I was also trying to achieve this, but apparently it’s not possible. I’m very used to the way that Figma works, where you can have a components library that automatically updates once you change the main component.
In Axure, I’m doing the following but it’s not working.
Create a new Library file and save as a Team Project file (in Axure Cloud)
Create a component, add a button
Check in component
Add component to the page
Check in page
Now, open a new file and pull that library
You can see the library item there
Drag to the page
Go back to the library file
Check out component, make changes, check in
Then I get stuck. I see the changes in the library on the other file, but if I make changes to the original component, it doesn’t change the component already placed on the page in the new file.
This whole process is quite cumbersome. I don’t know what to do anymore.
