Just discovered this issue as we are importing icons from our design system. When you import an SVG and convert from image to shape, the bounding box will sometimes appear to be larger than the shape. When I investigated, I found that it matches the outermost points of the control handles. While I guess this could be technically correct, it m akes it difficult to correctly size the actual shape.
