When Recreating an Admin Prototype, Do You Really Have to Start from Scratch?
When rebuilding an admin prototype, we often spend most of our time taking screenshots, measuring spacing, redrawing tables, and filling in text.
But what truly needs to be designed is not the interface itself — it’s the interaction behind it.
That’s why I created a browser extension called Copy to Design .
It allows you to copy an entire webpage, or selected areas such as tables, navigation bars, forms, dialogs, and other UI components directly into Axure. From there, you can build on top of these editable visual foundations and focus on designing states, flows, and interactions.
1784312999201-Cap 2026-07-18 at 01.28.22
The workflow is simple:
  1. Open the webpage you want to reference
  2. Select the full page or specific elements
  3. Copy them into Axure and continue designing your interactions
Of course, it’s not a magic button that generates a complete prototype with one click. Business logic, dynamic interactions, and complex states still require thoughtful design.
What it solves is the most repetitive part of the process: reducing manual recreation work so you can start real interaction design faster.
The extension now also supports copying designs into Figma .
If you often research competitors, modernize legacy systems, or quickly create admin prototypes, give it a try.
Chrome: https://chromewebstore.google.com/detail/kagheljiohdefkdlhmjiknfkcdjdcpok
Edge: https://microsoftedge.microsoft.com/addons/detail/plgjggmgpiibpddgkekkelbepgkcegmf
Worth flagging one practical caveat: copying a live competitor page tends to bring a lot of baggage with it — nested wrapper divs, inline styles, tracking scripts’ markup — so the imported result may look right but be awkward to edit or resize in Axure. Pasting into a scratch page first and cleaning up the hierarchy usually saves time later. Also check the source site’s terms before lifting whole screens into client-facing work; pulling layout structure and spacing is generally safer than reproducing branded content and copy verbatim.
Hi rachelgarcia, thanks for your sharing and reminder :blush:
For the nested layers that are tricky to edit, you can use the shortcut Ctrl+Shift+G to ungroup them. Our tool also consolidates large amounts of text and elements into a single element to make further editing easier.
In my workflow, I capture AI-generated interactive prototypes and import them into Axure to write interaction specifications. This approach generally doesn’t raise any terms-of-service concerns.
Feel free to reach out if you have any other questions or feedback to discuss.
