If you design too many pages in one artboard, it will be stuck. There is a delay when dragging to zoom in.
Hi @zhangchonglei,
I’m sorry to hear about the lag. To troubleshoot the issue, could you write into support@axure.com with your .rp file and any relevant information that might be helpful for us to reproduce on our end? One step you could try in the meantime is to optimize any images you have in your file to see if that helps speed things up a bit. Thank you!
Uploading: ceshi.rp…
I sent you an email yesterday with the prototype file attached, but I haven’t received a reply yet.
Thanks for following up about this! We’ve received your email and have responded with some questions to further investigate and troubleshoot what may be going on.
可以先用鼠标中键拖动试试,我是暂时这样解决这个卡顿问题的,我也提了个帖子。所以我怀疑是不是中文字体的问题。You can try dragging with the middle mouse button first. This is how I temporarily solved the lag problem. I also made a post. So I doubt it is a problem with Chinese fonts.
The middle mouse button worked for me to fix the lag. It might be worth giving it a try.
我后来发现是微信输入法的问题,你可以切换英文试试
