why droplist don’t support multiselection ?
Why droplist don't support multiselection ?
Alyssa_Axure
Hi! Droplist widgets don’t allow multi-select, as typically only one option is chosen from droplists. If you’re trying to build a widget that allows multi-select, then we would recommend using the listbox widget instead, which includes this functionality.
Multi-select dropdown menu
system
closed
