Although “Widget Text” is selected in “Generate Specification” -> “Widgets” -> “Select…columns” the column in the specification is empty. (The coulumn header is exported, the fields below are always empty.)
Axure V.9.0.0.3654
Is there a workaround?
Hmm, does this happen to occur when the “Only include widgets with Widget Notes” checkbox is selected? Generating a specification with this selected will only display information for widgets with widget notes. If possible, please try checking your specification and try deselecting this option. If any issues persist, please ensure that you’re running the latest build of Axure RP 9 (you can check for updates by navigating to “Help > Check for Updates”.
