What you want to do is possible but there are a few caveats:
Axure can’t generate new objects “on-the-fly” so you’ll have to create a dynamic panel for every component that can be dragged out.
For example: if your component library has 10 different types of components. You want users to be able to use “Component A” 5 times, and “Component B” 3 times, and “Component C” 8 times, etc. You will have to make 5 “Component A” dynamic panels, 3 “Component Bs”, etc., and have them stacked up in groups.
If these components need to interact with each other, your IF/THEN logic can get very long and complicated.
