I’m trying to wrap text in a droplist. I’m working on a mobile app, and I want the text in my droplist to wrap. It looks like it’s going to wrap, but when I hit preview or publish the changes, the text doesn’t actually wrap. Any ideas? Thanks!
Wrapping in Droplist
Alyssa_Axure
#4
Hmm, it looks like different browsers handle the non-wrapping text a bit differently. As far as droplist widgets, these are one of the Form widgets in the default library that are actual HTML widgets whose appearance and behavior is defined in the browser in which they are viewed; as such there’s limited customizability for these in Axure RP 8.
If you need the droplist to behave differently than it currently does, then I’d recommend trying out a custom droplist, which should give you more control over the behavior and appearance across browsers:
https://www.axure.com/support/training/custom-droplist-tutorial
Hopefully that helps!
