Hi there, hope someone can help.
I am trying to show on a little example how keyboard control in a table works. Everything is set up nicely, header, 6 entries, filter-bar can be turned on / off (no function). Two buttons that are only enabled, if an entry is selected. All entries are in a selection-group.
It works great with the mouse. when given focus with the mouse, the keyboard can also be used to select other entries (with key up and key down).
Now: when I hit “tab”, naturally the next entry would be selected, which I don’t want. I use key up / down for that. With “tab” I want to focus the buttons underneath the table. So each of the six entries has another condition for key pressed, if the key is “tab”, select the first button.
Now my problem: It does not matter where I press “tab”. the first button is ALWAYS selected. focus in the search field? tab jumps to the button. focus on a field in the filter? tab jumps to the button. None of these widgets have a “key pressed” interaction.
This really screams “bug”, but maybe I have done something wrong in my setup. I cut out the part with the table from my original file and changed fonts, colors and texts. So it is not pretty
Does someone have an idea?
keyboard_troubles.rp (130.9 KB)
